YnotTurbo wrote:
donn0128 wrote:
If you need airbags, your overloaded!
This is not accurate. I have airbags and I am not overloaded. It helps with stability and keeps the load level.
I looked at your pics. Nice setup! What air pressure are you running in your bags when loaded? What is your pin weight?
In my opinion you look high in the rear and your RV is nose high. One pic shows about 25psi I assume that was unloaded?
My 11 same truck as yours I ran 30 psi loaded and it ran level with 4K pin then with 5K later it was a tad low in the rear but looked fine and handled good.
Here is my 15 with air ride, 5K pin in "alt trailer" mode.
