batmackExplorerNov 27, 2014Air bagsMy 5th wheel RV dry weight is 7530 lbs and loaded is 9950 lbs. Truck is 2014 F250 6.2L 4X4 Crew cab (max load 12,200 lbs). Would there be any benefit installing air bags on the truck ?
Cummins12V98Explorer IIINov 27, 2014The bags will help with ride at a low psi like 30. If your rear is lower than level when hooked up then IMHO you need a heavier duty truck.
Related ContentSuspension Air BagsAir-bag LevelingAir bag life spanDual air bagsAir bags and Equalizer????
