rthibodaux
Jan 26, 2014Explorer
air bags
My financial adviser finely gave me permission to buy air bags for my 2013 dodge dully 3500 with 6.7 diesel. my question is What is the preferred one to buy. thanks
Me Again wrote:NC Hauler wrote:
I'd wonder if the hitch is too far back (toward rear of truck)...I had a 2010, loaded with present 5er, pin weight of 3300#, and it didn't squat ANYWHERE NEAR the picture I'm seeing of the OP's...The 13' with newer frame and beefed up suspension is a little better not dropping as much...
Something just don't look right with pic...again, is hitch located correctly in the bed of the truck
Where is OP, maybe that tool box has a 70 gal diesel tank in the bottom? I did the math on that models dry pin weight to shipping weight and it was 22 percent. Apply that to the GVWR of the trailer and it was around 3200 pounds. Something does not add up. It wound if he moved the spacer under the spring pact to the top. Or if someone grabbed 2500 springs in place of the 3500 springs on the assembly line. Trailer does appear pretty level.
Maybe he will come back and post a full side on picture!
Chris
