RoyB
Jul 06, 2014Explorer III
You need to tighten the four long bolts so that you depress the 14IN by 14in gasket between 1/8inch to 1/4inch. These four long bolts are the only thing that holds down the top unit sandwiched to the bottom unit.
Probably the gasket is losing its firmness and needs replaced. I did work my four bolts lose when I was traveling between TN and AL going down a very bumpy I59 however. The bolts were so loose I could see my top unit a/c unit moving around...
This gasket and freezing up of the top unit evaporator are about the only two things that cause drips inside the trailer.
photo from google search
Roy Ken
Roy Ken
About Fifth Wheel Group
19,043 PostsLatest Activity: Aug 23, 2026
