I was up on my roof today and I noticed a lot of bubbles on the rubber roof I had it treated and cleaned earlier in the year is it normal to have air bubbles in the rubber
Getting a rubber roof to lay perfect is not easy but shouldn't be a problem for roofs that are installed in a controlled environment. a few small bubbles should not be a problem but anything else is poor installation and should be watched. Use a sharpie or other magic marker to outline the bubble and make sure it doesn't grow over time. If it does then I would slice it open make sure it is dry and re-glue the section then patch over the slice.
