Cummins12V98
Sep 02, 2013Explorer III
motorcycle jack wrote:
I will run the truck at #5 of pressure with out the 5th, but after I'm hooked up I run it at the level line (about #85. When going to disconnect I run it down to #5 before unhooking since that lowers the unit so the hydraulics don't have to be so high and I'm going to run the truck at #5 anyhow after disconnecting. Always done it that way so the bags aren't super full with no load.
If you are lowering the psi to 5# while hitched you will have much less psi when you are not hitched. I run 5# when empty and once I put the 4,500# load on it I am at around 30#.
About Fifth Wheel Group
