tj548
Apr 10, 2017Explorer II
98silvz71 wrote:Old-Biscuit wrote:
That 'Next Level' TH by Holiday Rambler is a very nice rig.....well made but heavy
(17K GVWR) hence the need for those air bags on that SRW with a 14K tow rating.
Nice truck.
Best of luck
Per Ford's website he can tow 20,600lbs for fifth wheel assuming he has a Crew Cab Platinum (which is what the grill looks like he has) for a SRW with either 3.31 or 3.55 gears. Max GCW is 28,700lbs. Max conventional towing is 15k.
This is very close. Max GCWR is 28,900, max towing fifth wheel is 20,600 and both are numbers which I can stay under. But this trailer puts me 120 lbs over max on the rear axle but significantly over GVWR. With the trailer axles positioned where they are, the trailer really is better suited for a DRW due to excessive pin weight. I'm not sure how long I'll have this trailer but it is well controlled with some extra mitigations including the airbags. Super solid and confident going down the road.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
