tj548
Apr 11, 2017Explorer II
IdaD wrote:
Are you within your tire ratings? I'd worry about that more than being 120 lbs over the axle rating.
I agree, tires are usually the most vulnerable point. The Toyo RT 37/12.50/20 are 3,750 each or 7,500. I'm good there but I still pay attention. I've learned to watch the tire psi on the dash as I tow. I set them all to max (65 psi) before I start in the morning and then watch the psi creep up to 71 -73 ish as the day goes on. Front tires were about 2 psi less than the backs which means more heat in those. They bear and drive the load so they do almost all the work. I find this an interesting way to keep track of tire temps. If one or more of the tires started reaching 75 psi I'd know something is wrong.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
