tj548
Apr 13, 2017Explorer II
Cummins12V98 wrote:tj548 wrote:
I agree. Inflating to 80 psi levels the rear end and removes the bounce.
Are you serious? 80psi? You must be AZZ high with your truck with those pressures.
Check out the pictures at the end of the video. It shows the truck's rear end height at 5 psi and 85 psi in the airbags. They need 85 psi to level the rear end. I only run that pressure with the trailer attached of course and 5 psi when not. No need to put any pressure in the bags with no load.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
