nayther
Apr 03, 2018Explorer
OldLady wrote:
We just purchased our first 5th wheel. 1999 Alfa Ideal. It did not come with batteries so now we don't know how to wire them in. Nor can we find a manual online. Can anyone help us with a manual, diagram or photo of the battery hook up?
Thanks!
Did you find where the battery goes? One wire will probably be black and very large and connected/bolted to the frame, that is the ground. The other wire is probably red or white again very large and it is the positive. An ohm meter or volt meter with small batter can help sort out the other wires, there are usually more than one.
But if you really have no clue I'd suggest taking it to someone that knows what they're doing as you risk shorting out electronic items if you hook it up wrong.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
