cummins2014
Aug 16, 2020Explorer
time2roll wrote:
TOW-MASTER STR has the LRF if that is what you want.
https://www.greenballtires.com/brands/greenball/tow-master-str
Those Towmasters F rated are rated for 3960 lbs. @ 95 psi. At that point might as well go a G rated @ 4080 lbs. @ 110 psi . Get the best tire he can.
If he is wanting an F rated tire ,then most likely he has wheels rated for 110 psi. If not then he going to run either a F or G rated @ 80 psi. , and that would still be sufficient for his weight.
About Fifth Wheel Group
