MFL
Aug 16, 2020Nomad II
cummins2014 wrote: "I would rather be a bit over tired then close to the tire rating"
I agree, a BIT over tired, such as E-rated and 80 psi, which is more than enough tire for less than 10K on the trailer wheels. Running a heavy tire designed for 95-110 psi, at 80 psi, makes little sense, will run warmer, not roll as free, and cost more. IIRC, the OP's trailer came with D-rated tires, which are sufficient for the weight. To upgrade, a quality ST with an E rating at full sidewall of 80 psi is best choice, IMO.
Jerry
Jerry
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
