cummins2014
Aug 16, 2020Explorer
time2roll wrote:cummins2014 wrote:
Endurance the max air pressure is 80 psi. 3640 max weigh rating.
The weight chart shows Endurance at 110 psi and 4400 load.
https://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
Yes Sailun shows same. Either is fine.
I don’t think thats correct , the specs on the Endurance says 3640 max weight , 80 psi max Inflation, if it was otherwise the specs would show the 4400 and 110 like it does the Sailun. I think the inflation chart is messed up , 110 psi in a E rated tire ,I don’t think so.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
