jjj
Jan 07, 2014Explorer
When I replaced my leafs on my 6000 lb. Axles I went from a 3000 lb 4 leaf to a 3300 lb. 6 leaf there were only 2 lengths to use 25 1/4 or 24 7/8 I had the longer spring and the one I used was the.shorter because my wheels were so close together and it worked perfect. Measure you spring with no weight on it from eye hole to eye hole and if it is the 25 1/4 get the 24 7/8 one. I got mine from etrailer.com and I have not had any problems with them.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
