restlesswind
Jan 07, 2014Explorer
howardwheeler wrote:
I have a larger Alpenlite that has 7000 lbs Dexter axles with the adjustable spring hangers. If yours has the adjustable height hangers with never lube hubs I am fairly confident that you have 7000 or 6000 lbs Dexter axles which any spring shop will have exact replacements for. I broke two of my springs last New Years and wound up replacing all four springs and put an extra leaf on them. My trailer actually rides more stable now and have have peace of mind that it isn't going to break again anytime soon.
If you have the 7000lbs pair Dexter springs:
Relaxed (Unloaded)...24.88" eye to eye.
Loaded...26"
Part #072-027-00
8,000 lbs,pair....part #072-079-00
I just had mine replaced.I was told that Dexter no longer makes the 7,000 lb spring pair.
Off the shelf spring set will not fit correctly if you have Dexter
springs.
Having gone thru this twice,I can be sure of the above.
I ended up with the 8K pair to replace the undersized 7k pair,
I'm satisfied with the switch.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
