DesertHawk
Aug 31, 2013Explorer
Old-Biscuit wrote:
'Cold' means tires have reached ambient air temp.........not run for several hours.
Tire mfg. have already figured in the 'heat index' for pressure increases
So in the morning.....check adjust tire pressure
Then when you get to a different place.........check/adjust as necessary on the morning of travel.
Yes, I agree with OldBiscuit.
I've also been told, if your tires are low they will also heat up more & increase the pressure more. Much better to have higher pressure when starting out.
About Fifth Wheel Group
