tcamper's avatar
tcamper
Aluminum Roof Trusses - Grand Design uses Wood Trusses ???
One of my priorities during my search for a new 5er is a 6 sided Aluminum infrastructure ….. with aluminum roof trusses.
My thinking all along is it is easier to recover from water intrusion damage, if insulation and paneling is all you need to replace; whereas wood rot is a major structural repair…on top of the insulation and paneling. And isn’t metal to metal bonding more rigid than metal to wood bonding?
We are days away from pulling the trigger on a new Grand Design Solitude, and I have just overlooked the aluminum frame issue because I was told in July the Solitude has the aluminum roof trusses. And on the Grand Design website in July 2015 under the features it clearly states “Aluminum Frame Construction” (no mention of only 5 sides). In the early days this was a show stopper. We automatically eliminated rigs that did not have 6 Aluminum sides. The RV industry is filled less expensive, lower quality rigs with 6 sided aluminum infrastructure.
For a company that is setting new standards in the RV industry, why does GD use wood for the roof trusses? Is it a cost cutting measure? Is there an advantage to wood over Aluminum?
We are literally considering pulling the trigger this weekend, and this just occurs to me. This is a probable show stopper !!!!
Aluminum roof is a big deal to me so ……Why wood trusses? What am I missing?
Note: I have posted this question on the GD forum.
  • I'd be more concerned about the OSB roofing material than the framing members. Wood is used extensively throughout on TT/5ers for roof framing. I would have no qualms about it.
  • N-Trouble wrote:
    You speak as if roof leaks are inevitable/expected. Keep up on roof maintenance/inspections and likely not an issue.
    X-2 maintain the roof and you won't have to worry about leaks. Also make sure to check the seal around the windows.
  • I'd sure like to know what those "new standards in the RV industry" are...They don't look any different than any other mid priced RV to me..
    B.O.
  • You speak as if roof leaks are inevitable/expected. Keep up on roof maintenance/inspections and likely not an issue.
