True_temper's avatar
True_temper
Aluminum wheel blow out
I have a Jayco eagle with 6 bolt aluminum wheels. Right after I got it I put 14 ply tires on it. I never looked to see if the wheels had a pressure rating on them. I changed the valve stems to high pressure ones. Has any one actually seen or had a wheel blow apart from 100 psi in it? Pulled it a couple of years no problem so far.
