msmith1_wa
Apr 08, 2015Explorer
Your math is correct, but it not your tounge weight. If you had a 5er or gooseneck it would be your hitch/pin weight. Because the load is several feet behind the axle this distance needs to be taken in consideration for the calculation. To further complicate the math I presume your weight distribution bars were hooked up.
About Fifth Wheel Group
