IdaD
Apr 26, 2018Explorer
Durb wrote:
If I recall, the AUH minimum height setting is rather high relative to other hitches. Add an adapter and you are getting up there. I would call Andersen and the adapter manufacturer to find out how tall the overall assembly would be and see if it would fit the height limitations of your truck/trailer. Don't forget about the thickness of your pin adapter. Don't want to start out self imposed nose high.
The aluminum version is gooseneck only, so there would be no adapter if OP bought it. The rail mount version would need an adapter to fit the factory pucks. I don't know if the adapter would add more height than standard mounted rails or not.
About Fifth Wheel Group
