cummins2014
Apr 28, 2018Explorer
tiger275 wrote:laknox wrote:
Depends on whether you want a clean bed when the hitch is removed. GN gives you a clean bed; rails don't. If it doesn't matter, then go with what's easiest.
Both options I am considering would leave me with a clean bed since even the rail version I would use the quick install/remove picture frame adapter to my OEM puck system
The Reese adapter 30156, and the Andersen rail mount hitch would be a great combination, and can be removed as on unit if desired or separate , your choice.
Now that I have the Andersen I take them out separate by hand. No need now for the electric hoist in my garage that I installed when I had that heavy Reese slider.
About Fifth Wheel Group
