cummins2014
Apr 30, 2018Explorer
Cummins12V98 wrote:
I learned my "FACTS" on the Andersen causing bed deflection towing heavier with the aluminum model from someone that actually sells them and has bed deflection in his RAM towing a MobileSuites.
Where did you learn your FACTS about Ram trucks towing with the B&W ,and the bed damage the B&W hitches were doing until they started shimming the bed. If not mistaken you are one of the members here who reported the fix with the shims.
It's no secret that without the shims some get bed deflection with the B&W , as well as the Andersen, and some don't. But you choose to just bash the Andersen instead of sharing the same knowledge that you shared about he B&W .
Here is a FACT that you to not want to share. The Andersen aluminum hitch when shimmed in the valleys of the bed corrugation WILL prevent the same bed deflection as the B&W, without those shims, the B&W, and the Andersen can cause bed deflection ,and damage. Thats a FACT.
About Fifth Wheel Group
