Cummins12V98
Jun 07, 2015Explorer III
ranchertx wrote:rskeans wrote:rhagfo wrote:rskeans wrote:
He's not pulling it with a goose neck. He's just using the goose neck ball in the truck bed. The Andersen attaches to the bed goose neck ball. The advantage is that he has full use of the truck bed when removing the 32 lb hitch. Check out Andersen ultimate 5th wheel hitch to understand what's happening.
Call it what you want, it is still a ball hitch, and requires safety chains in most states. It is not a 5et wheel in the true terms of pin and ball.
True. Safety Chains are certainly not a big deal. When I plug in to the 7-pin, and connect my 'break-away' switch, I also spend about 2 seconds each slapping the safety chains on the Eye-Bolts. I'm not sure I understand the revelance of your last sentence.
Fyi, in Texas, no safety chains required.
Why limit your travels to such a small State? :B
About Fifth Wheel Group
