- RustyJCExplorerLet me answer you this way....if ball hitches (including goosenecks) are superior, why aren't they used instead of 5th wheel (kingpin) hitches on Class 8 over-the-road tractor/trailers? Even those rigs towing double use pintle hitches to connect the dolly to the front trailer. As far as the implied integrity of the hitching arrangements, notice that safety chains are not required on kingpin-type hitches but are by some states on all ball hitches.
If you want to get into the design specifics, we can wade off into that discussion another time.
Rusty - Searching_UtExplorer
RustyJC wrote:
Searching_Ut wrote:
ramgunner wrote:
It would be great if they could make a replacement pin box with their system built-in, get it "type-accepted" by the manufacturers, and have it offered as a factory option. I once heard they were working on that.
I think we may see something along those lines in the fairly near future. For trailers as light as we're towing with pickups, a ball hitch makes a lot more sense than the kingpin hitch setup. Far fewer moving parts and as a result fewer potential failure and wear points.
That's certainly an interesting opinion. I much prefer the kingpin hitch arrangement for any number of reasons, but that's my opinion. I suppose the marketplace will ultimately decide...
Rusty
Out of curiosity, what would some of the any number of reason be? - RustyJCExplorer
Rusty - N-TroubleExplorer
Cummins12V98 wrote:
N-Trouble wrote:
What does locking the RV to the hitch accomplish?
It will keep someone from pulling the handle and have the possibility of the RV disconnecting from the hitch. Yes it can and has happened.
Do you ever look in your rearview mirror while towing? Its right there... Might be a concern with a traditional 5er hitch that would just slide off, but its not like its going to jump off the ball without some serious effort.
On the other hand someone could just as easily pull the latch on my B&W Turnoverball so kind of defeats the purpose of having a lock on the Andersen anyways:P - Searching_UtExplorer
I think we may see something along those lines in the fairly near future. For trailers as light as we're towing with pickups, a ball hitch makes a lot more sense than the kingpin hitch setup. Far fewer moving parts and as a result fewer potential failure and wear points. - Me_AgainExplorer IIIThis sounds like they had a failure of some sort and have addressed it with an upgraded product. Wonder what they would say to someone that request a free upgrade?
Chris - Cummins12V98Explorer III
It will keep someone from pulling the handle and have the possibility of the RV disconnecting from the hitch. Yes it can and has happened. - Dayle1Explorer II
IdaD wrote:
goducks10 wrote:
N-Trouble wrote:
Sounds like a good idea however if you were stuck somewhere and needed to have your trailer towed your kind of out of luck. Unless someone else happens to have an Andersen.
Why? Just remove the king pin coupler block. Then any truck with a 5th hitch can tow it.
He's responding to the idea of eliminating the coupler block and just having a pinbox on the fifth wheel that is itself compatible with dropping onto the Andersen gooseneck ball.
There is something like that available already, a rotating pin box with a king pin on one side and a ball socket on the other side. - IdaDExplorer
He's responding to the idea of eliminating the coupler block and just having a pinbox on the fifth wheel that is itself compatible with dropping onto the Andersen gooseneck ball. - goducks10Explorer
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 22, 2025
