Jkmrich's avatar
Jkmrich
Andersen Hitch questions
Hello everyone. I decided to go with an Andersen UH. I have a couple questions for you with experience using them. I have a 2019 F250 standard bed.
Do you have bed rail clearance issues?
Can you make a 90 degree turn?
Does your FW ride nose high?
Are you having to use blocks to raise the FW high in order to drop on the ball?
Thanks for your input!
    Not a Ford but:
    No
    No
    A little
    No
  • A lot of those questions are determined by what you are pulling. I can turn 90 and have no rail clearance issues pulling a Grand Design 303RLS. Runs a couple of inches high. Nose height and rail clearance really aren’t different than any hitch. I could make it ride level, but rail clearance would be tight. You also have to realize that bed clearance can go away instantly with a very small difference in truck and trailer altitudes.
    I’ve never needed blocks to hitch or unhitch, but I can see it could be possible to get in a situation you might need to.
