Me Again wrote:
Well I guess you failed HS physics as you can not pull and push at the same time.
Of course you can't PULL and PUSH at the same time, you'd go nowhere. That's not HS physics, that is common sense.
I have been unable to find any reports out there of a failure in either one of these hitches (which is not to say they may not be there). I happen to have faith in the engineering of the products. Having had both a conventional fifth wheel hitch and now the Companion in my current truck, I would take the Companion any day. Presuming the Anderson continues to get the great reviews and there is no negative information about them, I will likely get the Anderson on the next truck.
