Walaby
Oct 13, 2021Explorer II
Jackathan wrote:
I have the steel Andersen. The instructions that came with the hitch stated to re-torque the top bolt after placing the full tongue weight on the ball. So, after lowering the rv onto the ball, I loosen the two locking bolts, and re-torque the center bolt, then re-torque the locking bolts. Makes a big difference in the towing experience. I only do this once, when installing the hitch. Then, for subsequent hitching and towing, I don't adjust it. If I remove and re-install the hitch, I perform the procedure again. Andersen address this in the FAQ here: https://help.andersenhitches.com/faq/what-should-be-the-torque-of-the-top-bolt-on-the-ultimate-fifth-wheel-connection-hitch
Thanks Jack - I don't recall seeing that in the instructions. Just looked through them again, and no reference to the procedure at the link.
Yes corvettekent, it is a short bed. I haven't had to turn 90 yet with it, but it worked fine on this trip. Pulling out of drive way and making a tight turn, with wife standing outside and watching, she said no concerns getting close to cab.
Mike
About Fifth Wheel Group
