ssthrd
Oct 15, 2021Explorer
laknox wrote:Walaby wrote:
Round trip from mid-Georgia to Greenville SC for a nice long weekend.
About a month ago, I decided to switch from my Superglide auto slider to the Andersen Ultimate hitch. Not that I didn't like the superglide, I do, but I wanted the lighter hitch so it would be easier to remove from the bed between trips. Im not getting any younger, and I am using my truck a lot more as a truck, now that I have 7 acres of land to tend to.
So, install was a snap. Nothing really to adjust. I bought the gooseneck version, with the Andersen shaft, no slip pad and chains. Installed, torqued everything down, and all good.
Driving experience was not so great. Rough roads were REALLY rough with the hitch. I had recently driven over the same roads with my Superglide and it was not anywhere near as rough. Concrete interstate with any sort of roughness was really bad. Like a bucking bronco a couple of times.
I don't think there's anything "adjustment" wise, because it's all install and torque down.. no adjustments to be made. I have a RVing friend who has the same setup. We were camping together this weekend. He has a dually, I have a SRW. He says he does not get the bucking and rough riding I experienced.
On way back, overall not as bad, and the road close to home on southbound side is not as bad as the northbound side was heading out.
Unless there's some way to smooth this thing out, I suspect I will go back to the Superglide. Seems like the extra 200lbs the Superglide weighs really made the ride much smoother.
Wondering if others notice the same thing? Anything I can do maybe to the truck, or the pinbox to smooth things out? I like the hitch overall, like the weight savings, and like the ease of removal.I don't have air-ride on the truck, and have what I consider a standard pin box. Nothing fancy, not a Trail Air or nothing like that.
I won't buy a dually just to get a smoother ride.
Any thoughts would be greatly appreciated. Lets just try to NOT make this an AUH bash session.
Mike
I will tell you that some states, like AZ, do consider the AUH a gooseneck hitch and will require safety chains. Not that you're likely to get checked, but if anything happens, you're SOL; especially liability-wise. Also, because AZ considers this a "ball hitch", it is technically illegal to tow doubles behind one.
Lyle
^^^ This
Where I am in BC, a fifth wheel hitch requires no chains but a ball hitch does. The Andersen is a ball hitch.
About Fifth Wheel Group
