gkainz
Oct 15, 2021Explorer
ssthrd wrote:Walaby wrote:
Thanks for all the comments.
Couple replies back.
I didn't realize you could install the hitch two ways. I guess in theory that makes sense, I just followed the stickers on the hitch that pointed an arrow towards tail gate and installed it that way. Guess it makes sense that it could go either way.. I was just following the stickers.
My adapter is mounted towards the rear. Based on the measurement instructions from Andersen, it called for it to be mounted that way.
I would check with Andersen before turning the base around. Physically, you can, but structurally, I don't think it's designed to carry the max load that way while pulling the 5er. Makes sense to me when I look at mine.
I put a stall mat under mine to mitigate against rotation, and it works great. After I hooked up the 5er, I re-torqued the top bolt and got another half turn or so......
I have my adaptor mounted towards the cab of the truck. ie, the cup/pin is closer to the cab to put the connection point over the rear axle. I still have lots of cab clearance, so no issue there. At the scale, the weight on the front tires changed by 20 pounds lighter from unloaded to loaded, so it looks like the connection point could still be very slightly behind the rear axle. Not enough for me to notice at all, and it handles great.
I did ask Andersen about reversing the frame on mine (1st gen original aluminum) and they said "no problem".
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
