MFL
Sep 29, 2017Nomad II
johndeerefarmer Most don't know that the aluminum bed on the SD is thicker than that of the F150.[/quote wrote:
[quote=johndeerefarmer Most don't know that the aluminum bed on the SD is thicker than that of the F150
I was wondering about that...good info JDF. I don't think I'd use the plywood base with the B&W 3500, even with your 150, as the plastic supports are meant to sit in the bottom grooves. If you did use the plywood, I'd remove the plastic runners first.
A call to B&W gets immediate answers to questions. They do a lot of installations at B&W, so they should have first hand knowledge with aluminum bed Fords.
Jerry
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
