DirtyOil
May 30, 2016Explorer
Second Chance wrote:DirtyOil wrote:
I use one of these:
http://www.shoprvparts.com/product/16524F/gooseneck-king-pin-stabilizer.html
or if you have one with the "cup" that the king pin sits in you could use a some plate steel weld a section of pipe to fit in the cup and either weld or bolt a ball onto the opposite side of the plate.
This type of goose-neck stabilizer would be great - except that all of the one's I've seen are too short to reach up to our Andersen adapters on the pin box. The modification suggestion is the only way I can think of to make things work.
Rob
You are right as it being on the "short" side, but I added some tubing, removed the "lower bracing" and added lengthened chains to the feet.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
