DirtyOil
Apr 30, 2015Explorer
Had the same problem. It ended up being my B&W Turnover was moving. Check all your bolts are torqued to spec on the B&W, especially the side plates. After re-torquing the B&W mine is rock solid. You don't need to torque down the Andersen more than the recommended 50ft/lbs
X2
your B&W turnover ball hitch bolts need to be torqued to 90ft/lbs. I would check those, do not over torque on the Andersen hitch bolts!
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
