Searching_Ut wrote:
I'll ignore the crows foot comment, as you haven't seen my tool box. It's way to heavy, and I can't find anything in it anyway. My truck tool box has hydraulic crimpers, multimeters, an oscilloscope, battery capacity tester, inspection camera, wrenches, sockets, jacks, chains for the truck and trailer, tow straps, hardware etc. etc. etc. I need to downsize, or buy a bigger truck already. Adding more....
You just explained the reason why I gave up on toolboxes several years back. One day I decided to clean it out because I had become so frustrated with the clutter and ended condensing everything I used frequently into a few rugged tool bags that could fit under the back seat. I've never looked back. My current TV has a flat bed with side boxes, which is more than I need.
The only defense I've ever given for the Andersen UH is against those who would question its rigidity in regards to rated capacity. Such critics usually throw out baseless assertions due to observing only a few issues. I think your situation goes to show that, while the product is an excellent design and idea, it may not be compatible with all rigs. I would love to see some follow up from Andersen regarding this and maybe some from LCI as well.
For me, the Andersen has performed flawlessly. I have a Mor-Ryde pin box, which does have a little thicker plate than the standard LCI. You can see the screw marks from the adapter, but they've not made any intentions. With my situation, the Andersen was/is the only option available for me. My bed height is too high to install rails and a standard hitch. The GN ball well isn't big enough for the B & W companion flatbed series to fit into. When I contacted B & W about making a longer shank for the companion, they said "no". I have the Andersen because it was my only option (other than a GN adapter) but it hasn't been a bad decision.
