Searching_Ut's avatar
Searching_Ut
Andersen Ultimate Issues
I'm coming up on the one year marks with the Andersen Ultimate steel version approximately 5k miles with the Bighorn, a around 800 miles with a Presidential suites. I've given up on the hitch as it's causing damage to both my truck, and my 2016 Bighorn 3270RS. So far the truck bed is pretty much just cosmetic from what I can tell, spray in bed liner flattened/indented. Judging by the bed flex though I feel time won't be good especially if we head to Alaska which is one of our plans.
The bighorn has a Lippert 1621HD pin box, the bottom plate of which isn't up to supporting all of the pin weight on the ends of the two set screws which carry all the load with the Andersen hitch adapter. See photos for issues. Dealer won't deal with the issue, and after approximately 3 weeks Andersen isn't saying anything yet either so being as how I have a long roadtrip planned for the near future, I ended up buying a B&W hitch, which is installed in the truck already, and Reese fifth airborne pin box which should arrive and be installed Monday.
Due to pin box length, ball adapter is installed with ball installed aft of pin. Collapse of pin box base plate was slow and progressive over the miles.
  • And for the last couple years a couple of us have been criticized for pointing out Andersen short comings. OK for lighter trailers, not up the the task for heavier trailers.
    Thanks for the honest feedback. Chris
  • Thanks for the honest report with pics! I think the Andersen would be best if used with rails, but still may have pin box issues.
    Using the bed for support on newer trucks is IMO, not the best idea, no matter what hitch.
    I think the puck system is the best overall, for standard hitches, and likely an Andersen style puck mount in the near future.
    Hope the new B&W works for you, with no issues.
    Jerry
