Dayle1
Jan 26, 2016Explorer II
Old-Biscuit wrote:
Surface area!
Anderson is a ball with a ball adapter for 5vr pin so very little surface area and 5vr articulates on the ball
5th wheel hitch has a wide plate on head, 5vr pin box has a wide plate on it and any articulation is with the whole hitch
This may be the difference, with a ball mount the trailer is completely unconstrained to roll independent of the truck. If your Reese hitch does not have side pivot, then the fiver is constrained until forces exceed the pin weight and lift one side of the pin box off the hitch head. If you do have a side pivot hitch, then seems like there should be very little difference.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
