goducks10
Jan 27, 2016Explorer
Bobandshawn wrote:laknox wrote:
Since you've moved your hitch point further back, you've got more leverage for the FW to move the truck. It only takes a couple inches to get this. Unless I had a =very= light FW, compared to my truck, I'd never have the hitch point behind my axle center line.
Lyle
I don't think he said he mounted it further back. I imagine if he has the rail mount he could move the rails back. If it's a gooseneck type ditto, he'd have to move the gooseneck back. The Anderson has no adjustment fore and aft.
If he has the rail version then you have two positions. You can rotate the base 180* depending on whether you have an SB or LB. You can also rotate the pin coupler.
If he has the pin coupler in front of the normal pin location and has rotated the Andersen to the rear for SB cab clearance then he's compounded the situation.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
