goducks10
Jan 27, 2016Explorer
Bobandshawn wrote:
If you have the rail system or the gooseneck system there is only one way to put it on correctly. Sure, you probably can turn it around, but it isn't meant to do that. The Anderson hitch that sits in the bed of the truck has one position. The king pin adapter can be moved around and being it is 4" on center there is actually an 8" difference between the forward and rearward position.
If you have the gooseneck mount version the gooseneck is in front! If it's in back the hitch is installed wrong. Look at the PDF on their website. If you have the rail system again ditto, only one way to put it on.
Then why does it tell you in the instructions to set the hitch in one way for LB and another way for SB? Also you can put the coupler block on two ways. Page 6 in the rail mount instructions clearly tells you how to install for LB or SB.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
