cummins2014
Jan 31, 2016Explorer
wvcampers wrote:Cdash wrote:
Look at the bright side. It wasn't tremendously expensive, and if your the only one with problems, you should be able to sell it pretty easily.
You are right. Next will be the BW slider. The reason I wanted to try the Andersen is because it is easy to remove from the truck due to it's light weight. I have used this Reese square tube slider for 5 years and I don't like all of the slop in the hitch. The advantage of the Reese is the height adjustment. I had it set to the lowest position. I have raised the fiver with the correct track so I should be able to use the BW hitch now.
Why not an automatic slider, if I had to do it over I would never go a manual slider again. IMO the manual sliders are a pain.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
