Me_Again
Oct 29, 2016Explorer III
Searching_Ut wrote:
As you know, the bighorns themselves set fairly high up, and there isn't much I could do to raise the trailer itself easily.
We have similar trucks and my Big Horn is a larger model. It is pretty level. There is a mod you can do to the rear springs by moving the spacer to the other side of the spring pack. It creates a bit of a problem with the removal of the pin/bolts in the disc brakes, however that does not have to be done that often. Chris
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
