Charlie_D_
Jul 30, 2016Explorer
OP-I am assuming this is a "new" problem? If so I would look in the area where the slide bar latches when pulled open for something bent or damaged. If not a new problem, have you tried to pull forward with the slide bar opened without you pulling on it? IIRC there is a bevel on the pin side. I also seem to remember there is a raised tab for the slide to latch on. Maybe it is bent down and not allowing the slide to latch far enough back. Please keep us posted.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
