x96mnn
Jul 30, 2016Explorer
Charlie D. wrote:
OP-I am assuming this is a "new" problem? If so I would look in the area where the slide bar latches when pulled open for something bent or damaged. If not a new problem, have you tried to pull forward with the slide bar opened without you pulling on it? IIRC there is a bevel on the pin side. I also seem to remember there is a raised tab for the slide to latch on. Maybe it is bent down and not allowing the slide to latch far enough back. Please keep us posted.
It is a new problem, have connected and disconnected over 300 times in the past no issue. I think the post before your post is my next step.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
