theoldwizard1
Dec 26, 2018Explorer II
jsrore wrote:
We also just bought a a Firman P08003 8000 watt generator.
i had never heard of Firman , did a lot of research and they get great reviews from all over the web.
the reason im asking about the converter/charger is not sure if it has enough power to charge the 4 T105 when i have the generator running...
Now is a good time to replace the converter charger with a combination inverter/charger/transfer switch. These are available from several different manufacturers including Samlex.
Simple installation. Wire your DC distribution panel directly to the battery bank and ignore the converter. Run external "shore power" directly into the inverter/charger/transfer switch. The transfer switch can handle 120VAC @ 30A so you can wire all of your RV AC circuits directly to the inverter/charger/transfer switch.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 15, 2026
