avvidclif1 wrote:
There is a big difference in using 4 tires rated for >14k capacity on a 12k GVWR trailer and using them on a 16k GVWR trailer. Most of the problems I have seen were when they were run close to max. You may be lucky.
And that is just the problem! The inflated ratings of ST tires based on the 65 MPH speed restriction is just that! INFLATED with no real construction or quality to support it.
There is a reason the all steel ply tires like the XPS Rib, Duravis R250, GY G614 and Sailun S367 do not fail. They are built to handle severe service from the get go.
34 lb wet noodle vs a 59-61 lb armor plated tank!
Chris
