laknox
Jan 15, 2019Nomad
TXiceman wrote:donn0128 wrote:
Depends on what the backing is. But yes its normal to see some wavyness on the sides.
Not normal. Our 5 year old HitchHiker is flat a a pool table along the walls.
If your trailer is the laminated construction, start looking for water intrusion.
Ken
If your HH has 16" center studs, you likely won't see the "waves". Newer rigs, which most likely =don't= have 16" center studs, will show the "waves", simply because there's less backing to hold the wall flat.
Lyle
About Fifth Wheel Group
