goducks10
Jan 15, 2019Explorer
Super_Dave wrote:
My understanding was that the walls are vacuum adhered to the adhesive on the studs. I could see the strength of the vacuum creating that kind of wavy look.
From what I've seen an adhesive is sprayed over the entire wall and the exterior wall material is then laid over that then pinch rolled or vac bonded. Most all fiberglass sided trailers don't have studs 16" OC so they rely on the foam insulation to be an integral part of the wall structure.
About Fifth Wheel Group
