- wandering1Explorer
routemaster wrote:
Call your 5er manufacture what I did.
X2
They made the 5er, they should know.Facts are always better than personal opinions. - meleavingsoonExplorerDoes the slide have a refrig. in it currently?
- routemasterExplorerCall your 5er manufacture what I did.
- Little_HandExplorerOur 2015 Montana 3711fl has the Samsung in the kitchen slide. My only question is why do they not have it so the ice maker will work? I can only assume the engineering team went to lunch when it came to hooking it up as it should be.:)
- pcm1959Explorer IIYou can find the weights of the various RV fridges on the respective manufacturers websites. Same goes for the residential units.
We replaced a 4 door Norcold with a 18 cu ft Samsung common in many RVs today and the weight was within a few pounds. - RustyJCExplorerI guess it depends on the difference in weight between the RV absorption fridge and the residential fridge and if (assuming the residential fridge IS heavier, which is not a given) the slideout is designed to handle the weight.
We have no problem at all with the large residential fridge in our road side kitchen slide.
Rusty - Jim-LindaExplorer IIMost weigh less than the RV ones.
Jim
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
