MO_Trout_Bum wrote:
Decided to take a winter camping trip over the weekend, and had a wonderful time. Except on the way home. About 30 minutes into the trip, left rear time blew a baseball sized hole in the top sidewall. Pulled over and changed to the spare (never been on the ground), and headed back out. 45 minutes later, the left rear tire (former spare) blew again... software sized hole in the same position. Called Good Sam roadside (scary/humorous experience there as well:E)and was back on the road with 2 new tires in a few hours. Thank heavens there was no damnage to the coach. Take away is, replace those POS Towmax tires as soon as you can. BTW, anyone have experience with Sotera? Assume it's another Chinese brand, but it's all the warehouse had. Will try to post some pictures/links of the first blowout. Hole is just left of 12:00 in the first picture and 5:00 in the second.
If you want to prevent that from ever happening again, or at least reduce your chances to about 5%, go weigh your unit prior to deciding on what tires to replace with. Once you determine what rated tires you actually need, then you can do some research to determine what brand and price you want to find.
