laknox wrote:
One thing to consider, if you have a newer TV, with HDMI inputs, you'll get even better picture than with co-ax, from an HD antenna.
LYle
Lyle, I think I need a little more info. Our four TVs range from two months old to 6 years. All of them do have HDMI ports. The signal from the roof HDTV antenna is through a standard RG-6 75 ohm cable. This is eventually (see my above reply to Old Duck above) hooked into the back of the TV using it's RG-6 connection. Are you saying I should be connecting the cable into the TV HDMI port using an adapter from the coax RG-6 connection to the TV HDMI port?
Bill
