Old-Biscuit
Oct 15, 2016Explorer III
1 valve system would be a 3-way valve
Turn handle parallel with cold water line and water goes into WH Tank
Turn handle 90* so it is perpendicular with cold water line and water 'bypasses' WH tank. Goes to hot water line and then hot water plumbing. Check valve in Hot outlet stops back-flow into WH Tank
2 valve system.......
Have to CLOSE cold water inlet to WH Tank
Have to OPEN bypass valve
Check valve on hot outlet stops back-flow into WH Tank
Problem...
Incorrect valving
Bad valve
Bad check valve
Disconnect cole water inlet at water heater to check for bad valve
If valving correct then most likely bad check valve in hot out
Problem...
Incorrect valving
Bad valve
Bad check valve
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
