past-MIdirector
Jul 27, 2014Explorer
Only real draw back from being 25 in the Appliance repair business is getting service. In most cases it will cost double to triple what you would pay for a service repair in a stick and brick home. Mainly because of access.
Live span on most home refrigerator has drop from an average 18 years with 3 service calls back in the 90s to 7-8 years today with 2 service calls. Another myth is the house refrigerator does not need to be level to operate, read the manual that comes with a household fridge. They do need to be as level as possible for proper operation since defrost water goes into a small pan under the unit.
The biggest problem is refrigerators today use mostly circuit boards and this is the most common and one of the most expensive items other than the compressor to fail. Either one will fail prematurely from low voltage.
The use of a household refrigerator is an owner decision since there are advantage to both types used in the RV industry.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
